CHARGING PROBLEM???
Old Jan 31, 2007 | 08:18 PM
addicttamud's Avatar
Default CHARGING PROBLEM???
I've got a bf 750i. The battery drained on me while i was riding. new battery didn't fix it, drained it too. just ordered voltage regulator hoping that the problem. just wondering if anyone else has had the same problem? i do like to play in high water and mud. i don't want to troubleshoot to deep into the wallet. i've really been liking the information i get from this forum for the now problems, future problems and mods. if someone could help it would be great.
06 750i camo
k&n air filter
hmf slip on
26 x 12x12, 26x12x10 swamp fox
ams rims
dyna ignition to put on monday
Old Feb 1, 2007 | 12:29 PM
Hayashi's Avatar
If the voltage reg doesn't this problem, I am thinking you are having a wiring/connector problem. Check the rear BUS connector for corrosion. Do search in this forum for more info on where and how. Also, what is the terminal voltage at the battery while you are revving the engine at about mid-throttle? It should be 13.5+ VDC if your stator output is healthy. Sometimes defective EBC system can drain the battery too because its circuit has the dc power (always ON) with ignition key off. Good Luck.
Old Feb 1, 2007 | 07:45 PM
thanks 4 the reply. seen alot on bus connecters. prob my my next problem. in alot of water.does the grease work?
put the volt reg on seems to be working. cant find my volt tester so time will tell. rode around the yaed 4 awhile after work. it didnt take long to run the batery down enough it wouldnt run before. it did fine so i hope its a fix. cant wait to get my dyna ign monday to try it. lot of people like it. got snow last night and tonight so it may b to slick to tell a diff right now.
bf750i 06 camo
K&N filter
hmf slip on
26 swampfox&wheels
dyna ign monday
slowgsxr97
Mar 18, 2022 03:40 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
hondarider1234
Jul 21, 2015 11:53 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
