what color wire for winch installation
Old Feb 3, 2007 | 04:40 PM
njfishnmann's Avatar
Default what color wire for winch installation
Could someone tell me which color ignition wire to use for installing a warn winch on a 06 Rubicon?
Old Feb 3, 2007 | 06:06 PM
HondaMechanic's Avatar
none
Old Feb 3, 2007 | 08:46 PM
Thanks for the reply hondamechanic. thats what I did with my 03 rancher but was told if I plug something into the outlet with the winch tied into it, it may keep blowing the fuse. I don't use the plug for anything so I will use the black/white wire again.
Old Feb 3, 2007 | 08:55 PM
none
Old Feb 3, 2007 | 09:17 PM
thanks for the info. I will change out the fuse. I just joined this forum and happy I did. there is great info here. looking forward to chatting with questions and answers again.
Old Feb 6, 2007 | 03:33 PM
owdiss27's Avatar
I was told to use the pink wire and that is what I did and I dont ever blow a fuse or ever had to chnge one it works great.
Old Feb 6, 2007 | 06:36 PM
LittleBill's Avatar
Originally posted by: HondaMechanic
Yes if your going to use the power outlet you should change the fuse from 10a to a 15a
i hope to god your not an actual mechanic in real life. telling people to simply change a fuse, without changing the wiring to go with it, is just stupid. you think maybe, just maybe there is a reason they use a 10 amp fuse. if knew anything about wiring, you would know changing the fuse is not necessary nor should be done, even if it doesn't blow. i have always wired to the accessory port. have NEVER needed to change a fuse to a higher rating. thats a good way to get an electrical fire going
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
