oil coming out everywhere!!! help.
Old Feb 4, 2007 | 07:08 PM
lancec2c30's Avatar
Default oil coming out everywhere!!! help.
This weekend I took my yfz450 out into the shop and adjusted the valve clearance along with doing the cam mod. All went fairly well and we had no incidents putting it back together. Now After we got it finally started and warmed up I took it out for a test ride. I really noticed a improvment in the bottom end like many say and thought cool. Get back to the house and look down.... there is oil coming out around the head gasket, oil filler cap, oil cap on the crankcase, the oil line going into the resivior, the return line in the vale cover. EVERYWHERE!!! [img]i/expressions/face-icon-small-sad.gif[/img] does anyone know what is wrong?
Old Feb 4, 2007 | 08:31 PM
JLsparky7's Avatar
Sounds like you might of over filled it. Hows the oil level now?
Old Feb 5, 2007 | 12:43 AM
lancec2c30's Avatar
Well we figured it out, it was a rubber seal on one of the screws holding down the valve cover. WE put it back in and problem solved. Next thing is to figure out jetting for the mod? w/ a k&n filter what should I use for a different pilot jet? It doenst idle very well and is hard at starting.
Old Feb 5, 2007 | 12:53 AM
JLsparky7's Avatar
Have you tried adjusting the idle jet that you have?
Generally inbetween 1-3 turns is where you wanna be.
dirt ryder
Sep 27, 2015 09:22 PM
randycraft24c
Aug 5, 2015 02:50 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
