Oil pump replacement
Old Feb 6, 2007 | 08:41 PM
Rca1965's Avatar
Default Oil pump replacement
I have a redcat 110cc that i am trying to replace the oil pump, i need to remove the clutch to get to the oil pump, i bought the socket to remove the nut that holds the clutch on but can't seem to get the nut to break loose, is it left or right hand threads? is there some way to hold the engine still so i can break the nut loose? thank, Russell
Old Feb 8, 2007 | 11:03 AM
2or4wheels's Avatar
You can go to the parts store and purchase an impact driver for about ten bucks, it is a valuable tool to have when something is hard to break free.
It is powered by the blow of a hammer, as soon as you see it you will know what to do, and they have instructions with them. Your basket nut should be righty tighty, lefty loosey, so loosen it by turning left. What I usually do to hold gears in place if I don't have the room for holders is to put a copper penny in the gear mesh (careful, don't drop it inside the engine) to hold them steady. Pennies are soft, and won't damage the gears...then put one in the other side of the gear mesh to tighten..
-d3
SDR-II
Sep 29, 2015 01:06 AM
toonces
Jul 28, 2015 01:58 PM
Aitch
Jul 21, 2015 09:40 PM
trouttracker
Jul 20, 2015 11:54 AM
Mikea1978
Jul 4, 2015 12:37 PM
