sunl battery ?
Old Feb 10, 2007 | 09:45 AM
doubled1's Avatar
Default sunl battery ?
sunl 90 been sitting a few months battery is dead. i put the charger on it and the light turns green right away but it doesnt start it just clicks real fast when i press the start button. does walmart sell a battery close to this or an auto parts store. thanks
Old Feb 10, 2007 | 09:49 AM
billl2099's Avatar
yep our friends at wal-mart has this size. you can use eaither the ____5lbs or the ____4lbs both are the same size. the 5lbs have a little more cca's, but it relly doesn't matter
Old Feb 10, 2007 | 10:03 AM
doubled1's Avatar
thanks for the quick reply. another excuse to go to walmart
Old Feb 10, 2007 | 01:09 PM
cowgirl's Avatar
sunl battery, go to Advanced Auto they are 10.00 cheaper than WalMart.
Old Feb 10, 2007 | 01:15 PM
doubled1's Avatar
thanks only have auto zone and oreillys here. im going there know. thank you
Old Feb 10, 2007 | 04:39 PM
Kazooooma's Avatar
The Walmarts near me don't have this tiny 12v battery.
I got 2 of them at Batteries Plus. Paid about 25 each. Neither one is working right. I'm suspecting that charging them with a small 2amp charger is killing them. Some of these small batteries are only supposed to be charge with .5 amps.
Old Feb 10, 2007 | 08:25 PM
doubled1's Avatar
originally the charger was only on about2 hours so i thought it was dead but my wife left it on the charger for three days and it cranked. but it wouldnt start, so i completly tore it apart. i thought i wasnt getting any spark. i put a light tester in the spark plug wire and it didnt light up . so i traced everything and pushed everything together . sometimes it would try to start but die after a few seconds, and then nothing.but finally it started and ran, so i cleaned the carb and raised the needle one notch. it wasnt that cold maybe 40 degrees. never had problems before. so i'll finish putting it back together tommorow. i'll let you guys know how it works. thanks for the help
Old Feb 12, 2007 | 08:01 PM
doubled1's Avatar
i sprayed gas in the spark plug hole and it tried to start, so i know its the carb. the best price i could find on a local battery was $50.00. im sure i could find one cheaper online buy ill go the local route. thanks
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
Atvnewb88
Aug 13, 2015 06:48 AM
WILLLANE8302
1) Engine problems..
Aug 7, 2015 08:24 AM
