Break in period for Oil Change
Old Feb 12, 2007 | 01:13 PM
Uinthas's Avatar
Default Break in period for Oil Change
Just picked up my 07 BF SRA last friday, follwed the break in instructions listed here http://www.mototuneusa.com/break_in_secrets.htm seems to be a pretty reasonable & popular way to get things broke in. Question now is, it says you should change your oil after 20miles, I have 4 hours & 50 miles, I want to use synthetic & dont want to change it again at 10 hours, would you suspect all the shavings have dumped into the oil by now or should I wait to change it?
Old Feb 12, 2007 | 05:00 PM
Hayashi's Avatar
I don't think it really matters whether you do it now or just a few hours later as long as your filter is doing its job. It's not like chunks of metal debris are floating in the oil cirulation path all the time - they will be caught by the filter if any. Just make sure you use a quality oil and filter when you do the change.
Old Feb 12, 2007 | 08:44 PM
Uinthas's Avatar
I assume it would be fine to go with Synthetic at this point?
Old Feb 12, 2007 | 09:02 PM
v2rider's Avatar
Yes, you can go with synthetic, preferrably Amsoil[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 12, 2007 | 11:51 PM
guzzler2's Avatar
Take a look at this link...it's been around a few times, but still really interesting!
I hope it helps.
guzzler2's Avatar
Oops...let's try again.
Old Feb 13, 2007 | 12:07 AM
bombaman's Avatar
I've followed these break in procedures with no problems.
Old Feb 13, 2007 | 12:29 AM
guzzler2's Avatar
Sorry, didn't see your reference to the link in your first post.
My 2 cents...the first couple changes are very important. If you don't want to spend the money on synthetic for a short change, I would give it one more go with the regular oil and then switch sometime around 10 hr.
I have broken-in 2 of the Kawie twins with a couple of quick changes and then synthetic with good results.
Good luck!
Old Feb 13, 2007 | 10:58 AM
Uinthas's Avatar
Yea I want to use synthetic, but what oil? I know most use amsoil, but I havn't found a store around here who carries it, & I dont want to order it.. Also what is a good alternative oil filter to the kawasaki filter and part# if you have it. thanks
Old Feb 13, 2007 | 12:10 PM
bombaman's Avatar
Rotella 5w40 synthetic
