2002 honda foreman does it have this saftey feature
Old Feb 12, 2007 | 06:32 PM
rickhise's Avatar
Default 2002 honda foreman does it have this saftey feature
if anyone knows if the foreman 400 2002 model had a switched to shut the engine off if the oil got to low.
can anyone help me find what the minimum compression I can operate this machine safely and expect to get out and back.
I know it was damaged when the oil ran low, if ne of youknow someone on here I can PM or email that might help too
Old Feb 17, 2007 | 06:23 PM
1988TRX250R's Avatar
There is nothing that will shut off the engine if the oil is low except for when the piston seizes to the cylinder. It wouldn't be a bad feature, its on all of the generators they build. Compression should be around 80 psi. There is a built in decompressor to make starting easier which will make cranking compression lower than running compression.
MNatv89
Aug 10, 2015 02:20 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
MNatv89
Jul 7, 2015 11:36 AM
