Falcon FX-150 MKII question
Does the Falcon 150 have a separate oiling system for reverse? I was told there are two places on this bike to change the gear oil. If this is the case where do you add the gear oil and how much? I know the tranny has a sight glass for it, but what about the reverse?
Also on the Raceway Mini-Ute I noticed two drain plugs, one for the engine oil, and I am assuming one for the tranny. Where do you fill the tranny gear oil on this, and how much do you put in?
first on the mini only one drain plug, the one one the right side of the engine 17mm, the other cap is to adjust the timeing chain, the engine oil is shared with the trans oil.
second the falcon 150 has 3 places to change oil. the engine oil , transmission oil 75-90, and the reverse gear box also takes 75-90. the trans oil plug at the botton rear of the engine case,on the left side. fill plug is almost center at the rear of the cvt cover, takes just about 4oz, the revrese box gear oil, plug at botton of gear box . filler is the vent tube fitting, remove it, fill oil to top of site glass
Quadzilla Heritage
Sep 25, 2015 01:39 PM
