1999 500 magnum 4wd
Old Feb 15, 2007 | 11:38 PM
vetcogray's Avatar
Default 1999 500 magnum 4wd
hi everyone
i am having an intermittent problem with my 4 wheel drive
When i need it , it wont work
the light on the switch (awd) does not light up and i have no 4 wheel drive
sometimes it works in reverse when i push over ride button , but most times if no light , no awd
i have checked the electrical connections where they enter the engine on the right hand side, last time i put wd40 on connections and bike stayed stuck in awd!!unpluged connection , plugged back in and everything was fine
i have read the horror stories about the plastic cage , i too have had the bike pull to one side for no reason , put bike in reverse, backed up and everything was ok, so dont know if it was the diff acting up or not.
Could it be something as simple as adjusting the linkage from gear handle, noticed sometimes if i mess with gearchange it works ok and light comes on again.Any advice appreciated , like i said is intermittent problem so dont know whats gong on.Where are the fuses located?[img]i/expressions/face-icon-small-blush.gif[/img]
Old Feb 16, 2007 | 09:31 PM
Heinz01's Avatar
Could be the switch, or the wires are pulling out of the housing that are connected to the switch. Or the linkage is worn out inside.
Gwolf228
Feb 18, 2017 01:36 AM
rockinkgin
Sep 25, 2015 01:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
Sep 9, 2015 06:57 AM
