loose steering 500 magnum
Old Feb 15, 2007 | 11:53 PM
vetcogray's Avatar
Default loose steering 500 magnum
Anyone ever replaced the upper and lower bearings on 500 magnum steering column?
how big a job is it ?
Could a regular guy with a little mechanical aptitude complete the operation?
i have replaced inner and outer tie-rod ends but still have slack in the steering, the upper bearing definately gone prob because i have'nt greased the zerk as its hidden!
thanks
Old Feb 16, 2007 | 10:57 AM
Totun's Avatar
The upper is probably OK. I think it's the lower. It is a plastic bushing that is fairly cheap. It is attached by rivets, which is the hardest part of the job to remove. Could be filed or a small Dremel tool to zip them off. I replaced the rivets with bolts and Ny-lock nuts so it was serviceable. Make sure the attitude of the bolts doesn?t interfere with the inner tie-rod boots when you put it back together.
Totun
Old Feb 16, 2007 | 11:41 PM
vetcogray's Avatar
upper is definatly gone , i can see it moving.Any experiance with upper bearing?
i would like to replace both .Is this the type of job i could complete in 1 day?
Gwolf228
Feb 18, 2017 01:36 AM
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Sep 9, 2015 06:57 AM
