Fuel-Air adjustment screw?
Old Feb 17, 2007 | 10:42 PM
notmydayjob's Avatar
Default Fuel-Air adjustment screw?
Could someone contrast and compare adjusting the fuel air screw with re-jetting the carb? Do you really have to remove the carb and do some drilling like in the dyna-jet instructions to adust it?
Old Feb 17, 2007 | 10:57 PM
SPORTSMAN70003's Avatar
Yes you will need to remove the carb and drill out the brass plug like the Dynojet instructions say.
Old Feb 18, 2007 | 02:00 PM
So when do you adjust the fuel air ratio with the screw and when do you rejet?
Old Feb 18, 2007 | 02:34 PM
If you add performance mods or change to a different elevation you may need to rejet. You need to do plug checks to see if you need to rejet. If your lean or rich on idle you then need to adjust the fuel screw in or out.
Old Feb 18, 2007 | 02:52 PM
I am not rich on idle.... no smell... how do you tell lean on idle? Having finished up monkeying with the intake stuff I now need to choke it to start it and leave it on for 6-10 minutes of riding before it is stable.
Old Feb 18, 2007 | 02:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
lean is a condtion of lack of gas and too much air which in turn makes it run hotter. not a good thing if too hot. sometimes a lean cond. will caus back firing and check the plugs and they will run white instead of golden brown.
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Oct 10, 2015 10:20 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
