Pulled Drain Plugs. Have a Few Q's (400)
Old Dec 17, 2000 | 11:55 AM
Xplorman's Avatar
I decided to do maintenance today so I'm changing lubricants. I was surprised, when I pulled the recoil and starter drains to find oil run out. I thought they were water drains. Also, when I pulled the crankcase drain not much came out. Is this normal?? No surprises when I pulled the counter balance and transmission drains. What's up with the above though??
Old Dec 17, 2000 | 01:10 PM
QuadBuster's Avatar
The crankcase drain is there for preventative reasons. Its there in case you every blow a head gasket or get water into the engine somehow. Unless either one of these has happened, you should'nt get much of anything.
I blew the He!! out of a head gasket once and still did'nt get but a couple of oz. of gas/coolant mix out.
I know nothing about the recoil or starting draining.
Hope to have helped a little,
EC
Old Dec 17, 2000 | 10:07 PM
scramdaddy400's Avatar
I think your pulling the wrong plugs, check your owners manual.
GOOD LUCK
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Dec 18, 2000 | 08:40 AM
Xplorman's Avatar
The crankcase drain explanation makes sense. Thanks! As far as what plugs I'm pulling, I went right off the picture in the manual and their location makes sense looking from underneath. I need to make a trip to the dealer to get some trans lube so I'll see what they have to say.
Thanks for the help!
Old Dec 18, 2000 | 12:15 PM
MEANGREENMACHINE's Avatar
Well the crankcase only holds .93 quarts or oil. It isn't much. Now as far as the recoil starter goes, I have had oil come out of mine also. I don't know if it's because I put too much oil in the motor or what. It wasn't much. I don't think that it is anything to worry about. You should also drain the front differential and refill it with fresh gear oil.
Old Dec 19, 2000 | 07:09 PM
Jeremy H.'s Avatar
Meangreenmachine, do you have any pics of you quad. Sounds like a pretty cool setup.
jeremy H.
2000 scram 400 2x4, HPD pipe, clutch, silencer.
Njrider1230
Jul 29, 2023 05:16 AM
SDR-II
Sep 29, 2015 01:06 AM
Ronbo6270
Aug 6, 2015 11:54 PM
cornermike
Jul 30, 2015 06:37 AM
Shifts
Jul 3, 2015 07:59 AM
