How slow is too slow?
Old Feb 18, 2007 | 07:05 PM
BlueLightSpecial's Avatar
Default How slow is too slow?
Dumb questions here. How slow is too slow for high gear? Next question, SS112 wheels w/ 5+2 off set. How much wider will the track be? 4 inches, 14", 7"?
Old Feb 18, 2007 | 10:12 PM
montyh's Avatar
bluelight, i use low for when i expect to stay below 15 or 20 mph for a while. you will be able to tell after a few rides what feels right.
i don't know about the wheels
monty
Old Feb 19, 2007 | 09:34 AM
Hayashi's Avatar
How slow is too slow for HI gear?
Speed doesn't matter on the CVT system. What really matter is the amount of load or resistance on the wheels. For example, on a flat ground, you can just crawl in HI gear and it would not hurt anything. However, if you are towing something or going up a steep hill or going through mud or snow, you should use the LO gear whether you are going slow or fast, because you don't want to burn up your belt.
Old Feb 20, 2007 | 12:15 AM
alwaysride's Avatar
If you care about your belt life and such, just use LOW gear when going slow.
Old Feb 20, 2007 | 10:44 AM
Kawiking489's Avatar
agreed with Hayashi
Old Feb 20, 2007 | 10:01 PM
montyh's Avatar
there is a minimum speed the clutch can produce without slipping. the stall speed. it is like 7 mph in hi and around 3 or 4 in low. if you run without KEBS, this is the speed the clutch will disengage and let ya freewheel. if you run lower than these speeds, your are just doing a "controlled belt burn" to controll speed. anyting higher than these speeds is normal operation. i still use low range if i expect to go slow for a while...
monty
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
ReconBayou
Sep 23, 2015 02:41 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
firsttimerider
Sep 20, 2015 09:07 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
