Polaris Sportsman 450 WEork lights
Old Feb 18, 2007 | 11:26 PM
CoastyDad's Avatar
Default Polaris Sportsman 450 WEork lights
I recently picked up an 07 Sp 450. I see that there is work light wiring but no switch. How do I know which harness to use? Can I just buy a switch at radio shack?Is the harness already hot?What kind of bulbs do I use? Thanks in advance for thje help.
Old Feb 19, 2007 | 08:10 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i am "guessing" that polaris uses the same wiring harness for the a non back up light as for a working system. so if you can pull the pod off and find where the plug goes to the switch maybe by finding a wirng diagram you would be all set. polaris part no# 4011065 for the work light bulb.
Old Feb 19, 2007 | 09:06 AM
floodrunner's Avatar
You got the ?standard model? 450. All you need to make the work lights functional are the bulbs and switch. Polaris sells a kit (PN 2876090) that has both but I don?t know the cost. The wiring is already there at the rear lenses and inside the pod. Install the bulbs, cut a hole and install the switch.
Old Feb 19, 2007 | 10:29 PM
CoastyDad's Avatar
Hey Thanks for the info. I'll poke around inside the pod and see what I can find. Right now it's not a neccessity but at some point I'd like to use them. BTW went for a smokin' 32 mile snow trek along the power lines in Dutchess county NY today. 20 degrees but absolutely gorgeous out. I like mid life.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
yellowpolaris
Jun 21, 2015 11:13 AM
May 27, 2015 11:15 AM
guy
Feb 23, 2000 02:31 AM
