Trailblazer Clutch
Old Feb 20, 2007 | 10:00 PM
parafrog's Avatar
Default Trailblazer Clutch
Actually two questions here; 1) Recommendations for a good clutch kit, not really looking to increase top end, rather low and mid range. I'm NOT changing the pipe or anything else, just clutching it for now. 2) Where can I find a black seat or black seat cover for 2001 Trailblazer, any sites that you can direct me too???? Thanks in advance!
Old Feb 20, 2007 | 11:07 PM
ftwflh's Avatar
No need for a kit just get you a Polaris white primary spring.The seat you can find on Ebay and Trailblazer or Scrambler seat will fit.You can find cool seat covers there too.
Old Feb 21, 2007 | 10:57 PM
parafrog's Avatar
thanks for the info!
Old Feb 23, 2007 | 07:03 PM
parafrog's Avatar
bump!
Old Feb 23, 2007 | 07:41 PM
trailblazermudrunner's Avatar
what eles would u like to know
Old Feb 23, 2007 | 08:15 PM
onesavage's Avatar
hey i got a Q for ya.. i was going to put the porlais white spring in my 04.5 sportsman 400 , i bought it and since the i have ordered a HEELCLICKER kit... my blazer is stock everthing but board .40 over due to crank seals making it run lean...whats that white spring gona do for me ,, i already have it might as well use it ,, will it even work its for a 04 sportsman 400.... FTWFLH, what main jet should i be running stock or what its stock now!!!!!!!!!!! THANSK GUYS.......................
Old Feb 23, 2007 | 09:15 PM
well maybe it might make it kick in at lower rpm and give u some more pulling power
Old Feb 23, 2007 | 09:18 PM
Kerbbirds's Avatar
It will make it engage at a higher rpm wich will give it more power on the bottom end, but whatever you gain on the bottom you will lose on the top, it will run slower.
Old Feb 23, 2007 | 11:22 PM
ftwflh's Avatar
The white springwill give you a faster take off due to the higher(slightly higher)engagment rpm and will get you more top rpm over the stock spring.
On the jettingI cant tell you right off but pm me and this weekend I will get you the stock jetting for a 250TB.
Old Feb 24, 2007 | 12:04 AM
onesavage's Avatar
sweet,, thanks
