widen a e ton 40?
Old Feb 21, 2007 | 01:42 PM
shark66067's Avatar
Default widen a e ton 40?
Anyone know of a way to widen a little e ton rascal 40? Two of my older kids have rolled it turning in the yard and my 3 yr old is getting big enough now to start learning on it and would like to widen it for his safety and his mothers peace of mind. [img]i/expressions/face-icon-small-wink.gif[/img] Any help would be appreciated even if some has a home made set up i could get a look at it would be great Thanks.
Old Feb 21, 2007 | 03:02 PM
2002raptor2002's Avatar
i built a +6 in kit for my kids 90cc predator. I used flat iron brackets to move the mounting points for the a-arms out 3in on each side. i got the idea from diamondjcustoms.com. also moved the top shock mount out 3 in on each side. then i just bought the +3 in whell spacers for the rear.
good luck
Old Feb 21, 2007 | 10:54 PM
bulldogfallon's Avatar
How about using wheel spacers or offset rims or both?
On a small quad like this the bump steer from these add ons will be minimal
With a bigger quad I wouldn't recomend this..
These may be cost effective ways to get a little more stability
Old Feb 22, 2007 | 12:16 AM
shark66067's Avatar
Problem with the spacers and all is the wheels mount to the spindles not a hub may just have to relocate the front a arm mounting points on the frame out wider and reweld and the same with the shock mount. even when i resell it will be more stable and safe for the next youngin unless there are some other ideas?
2stroke4ever
May 11, 2002 01:59 AM
ProCircutBLASTER
Nov 11, 2001 04:29 PM
Kodiak01
KTM
Jul 30, 2001 06:18 AM
EZErriicc
Mar 5, 2001 01:29 PM
