bigger tires on 360 prairie?
Old Feb 22, 2007 | 05:23 PM
BassCatnc's Avatar
Default bigger tires on 360 prairie?
any of you guys who have upgraded your tire size, can you give me some of the pros/cons? what size would be best to go to, or would it be better to stay stock size, and get a more aggressive tire?
Thanks,
Mike
Old Feb 22, 2007 | 05:48 PM
Kawiking33's Avatar
From personal experience, I would say stay with stock size. The Prairie is already slow enough (for me).
If you want, go up a size, but I dont think its needed. A more agressive tire like the Mudlite series, or 589's would suit you. If your a real heavy muddy check out tires called "Super Swampers"
Hope that answers your question
Old Feb 22, 2007 | 07:56 PM
tencubed's Avatar
Being retired is a hoot!
I agree, the 360 is not a high speed machine and the stock tires seem to do just fine. One thing I really like about the stock rubber is they act as kind of a fuse for overloading the machine. I find that when I am using the plow or bucket to move dirt or other heavy material the tires will be flattened or loose traction prior to damaging the the quad.
Old Feb 23, 2007 | 03:14 AM
madmuddin1's Avatar
I run 26" gators on my 360 and when it's time to renew them I will be going back to the 25's. I run 25" gators on my wifes and she can go anywhere I go. I really only gained about 1/2" to 3/4" ground clearance with the 26" tires but I lost a lot of low and mid range torque.
Stick with the stock 25" tires you will not be sorry.
Mud
Old Feb 23, 2007 | 09:41 AM
sandpit's Avatar
I had 25" Mud-Lites on my 04.
Old Feb 23, 2007 | 07:35 PM
Todger's Avatar
I have 25" mudbugs on my wife's. They are fine. A friend has 26" and lost about 6 mph with them.
TK
Old Feb 24, 2007 | 11:08 AM
Tangier's Avatar
I have often debated this very thing as I would like a little more stability and traction over rough ground.
I have kept my stock tires and have been mostly happy with them ---- although I do use a tight fitting pair of chains in the winter. I would like to move up one size in width and keep the same height --- also a little more agressive tread --- maybe bearclaws or mudlites --- but always conclude that I am already underpowered and do not want to sacrifice anymore speed.
The chains in the winter work well for me for now.
Old Feb 24, 2007 | 09:27 PM
KVRMUDDRUNNER's Avatar
Our friend has a 360 with 26 mudlites. If it was mine i would just stick to the stock tire size but get more agressive tread like the mudlites. Those 360's are turds but you cant kill them. Damn good atv. I've always wanted to hop up a 360, that'll turn some heads but probably aint worth it unless i had a ton of money.
Old Feb 24, 2007 | 10:52 PM
GR8Outdoorsman's Avatar
I went with 26" 589s on my Prairie 300. They did slow the bike down 1-2 mph, but it didn't bother me at all. I very rarely run at full throttle any how. I did install the high-lifter lift kit as well. The 26" 589s would probably bottom out or rub when turning if I hadn't installed the lift. My advice would be to go with a more aggressive tire, like the 589s, if you plan on going through alot of mud, etc... Go with a lighter weight stock tire if you will be riding on dryer, less harsh terrain. Good luck!!!
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
Logan Collins
Sep 5, 2015 08:03 PM
