Polaris 700 lost all power!!! Please help.
Old Feb 23, 2007 | 03:21 AM
phi214's Avatar
Default Polaris 700 lost all power!!! Please help.
I have a 2003 polaris sportsman 700 twin and I had just got done washing it off at the car wash and started it up and was loading it back on my trailer. I pulled up on the ramps and proceeded to pull on the trailer and I lost all power and it shut off. I tried starting it and after turning the key a few times the dash lit up for a second and it started to turn over and then the power shut off again and I haven't been able to restart it again and it seems as though all power was lost and won't come back on. I took the light off and checked all the wiring behind it and can't find any breaks. Can someone help me or has anyone experienced this problem and have a solution? Thanks.
Old Feb 23, 2007 | 04:05 AM
akracingbioch's Avatar
try adjusting the carberator a similar thing happened on my 96 suzuki 250 it was running fine then shut off took quite some time to fix it, as for your headlike not sure batteries dont die out of no were in five seconds somthing might have short circuted but not sure if you should trust me im the retard who thought you could fix a big bear with duct tape
Old Feb 23, 2007 | 08:11 AM
SAshton's Avatar
check your battery connections, maybe there is corrosion on the terminals. maybe, if it's your original battery that it could be dead
Old Feb 23, 2007 | 04:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you lost all electrical power hafteer washing then check batery connections and go forward from there
Old Feb 23, 2007 | 09:20 PM
Hoyt34's Avatar
SrY dude but its because its a fat Polaris...[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 23, 2007 | 10:05 PM
jta4455's Avatar
there is a small wire coming from your solonoid, try cleaning that. You said you lost all power after washing, there maybe some corrosion in there. and i don't remember but i think there is a 20 amp circut breaker for the same wire that comes out of solonoid. Hope this helps.
Old Feb 23, 2007 | 10:13 PM
phi214's Avatar
Thanks man! I will give it a shot.
phi214's Avatar
Big help man. Thanks.
Old Feb 23, 2007 | 10:16 PM
phi214's Avatar
Hey Hoyt34! I was asking about fixing my polaris. If you have a comment that is good then share it. If you don't, then keep it to yourself. It's that simple.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
nature violator
Jul 3, 2015 08:40 PM
Mason1987
Jun 15, 2015 09:15 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
