missing snaprings on cv joint
Old Feb 28, 2007 | 05:09 AM
manomako's Avatar
Default missing snaprings on cv joint
I have a 2001 scrambler 500 4x4 that i just bought and the right front axle came out of the cv joint (which is the first mystery).
when i took it apart to replace the ripped boot there was no snapring on the end of the axle, actually it doesnt even have a notch in the end for one to clip onto, nor any groove in the splines on the end or further up. I thought maybe the groove got ground off the end of the axle, so i removed the other axle and it looked the same, no groove or notch.
is this normal for the later models or are these axle just old and worn?
also, how did the axle come out in the first place? doesn't the A-arm keep the axle in the joint? i know in tight turns there might be a more of a chance of the axle popping out, but i still dont see how it could have happened even without snaprings....
any ideas?
oh, here's another good one...when i make a tight left turn my throttle increases, it must be
stretching the cable somehow?
thanks guys!
Old Feb 28, 2007 | 06:17 PM
67cam's Avatar
i have an 05 scrambler and there is a snap ring on it, it also has a groove in the axle where it fits into. i also just check at bikebandit.com and it looks like your machine should have one also.
Old Feb 28, 2007 | 07:48 PM
manomako's Avatar
Thanks Cam,
i thought it should, i think i'll just see if it pops out again. If it does i'll replace the axles. I still dont understand how it could pop out tho...
Old Feb 28, 2007 | 10:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
your cable must be routed wrong or be struck on something that causes it to pull on it.
95wolv
Sep 27, 2024 12:00 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
tysonbully
Sep 28, 2015 02:30 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
89Lt250r
Sep 7, 2015 07:53 PM
