oil level rising
Old Mar 3, 2007 | 02:55 PM
dthack1881's Avatar
Default oil level rising
The oil level in my bike has risen a little. I checked the old threads on the problem and found out the manual says your'e suppose to run engine at idle for 20 seconds before checking it.that seemed to do the trick.the question I have is there were alot of people saying to smell the oil and see if it smelled like gas. Why would they be asking if the oil smelled like gas?
Old Mar 3, 2007 | 03:05 PM
ctateusa1's Avatar
If you have gas leaking into the cylinder and seeping past the rings it can cause the oil level to rise up on the stick.
Old Mar 3, 2007 | 03:08 PM
upnort's Avatar
Blow by past worn piston rings during the compression stroke. During the compression stroke on a four stroke it is compressing the fuel/air mixture prior to being ignited by the spark and it is under pretty high pressure at this point.
Old Mar 3, 2007 | 04:15 PM
hoytultratec's Avatar
bad rings, smell the oil.
Old Mar 3, 2007 | 04:40 PM
Zbart1's Avatar
1881
The reason they tell you to smell the oil is that there are only two things that can make your oil level rise.
1. Anti freeze leaking past a gasket or crack into crank case ( complicated fix )
2. Gas leaking past needle and seat into combustion chamber past rings and into crankcase.( easy fix)
You need to try and isolate which it is: by smelling and by observing coolant levels
Old Mar 3, 2007 | 06:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as stated you do need to run the engine first and then check the oil. wierd way of doing it but oh well works. if you had a serve flooded bike it would but gas in the base and make the oil rise and smell of gas. pray you never have antifreeze in your engine as zbart says, compl. and expensive.
Old Mar 4, 2007 | 08:56 PM
dthack1881's Avatar
Yea I just had the mechanical water pump seal changed last week.Thats why I was worried..thinking maybe while the seal was leaking it caused the oil seal to go bad.But wouldnt the dealer have noticed the oil seal if there was a problem with it when they were replacing the mechanical seal on the water pump?........anyway if there was coolant in the oil wouldnt it be milky............the consistancy of the oil seems fine.Ill know after I replace the cv boot so I can ride it again and check it out better........One problem at a time...lol[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Mar 4, 2007 | 09:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes the oil would be milky. didnt you say that after you ran it and then checked the oil it was fine?
Old Mar 4, 2007 | 09:22 PM
dthack1881's Avatar
Yes... but Im not sure why my coolant level is low...havent had a chance to buy any yet and check it all out.
Old Aug 22, 2021 | 07:57 PM
Atuey's Avatar
Default Oil rising
Would this worn out piston cause an increase in fuel consumption?
Beeline08
Nov 11, 2016 04:00 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
panicmanic
Sep 28, 2015 12:59 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
