Trail Boss 250 not charging
Old Mar 3, 2007 | 05:38 PM
godIlove2ride's Avatar
Default Trail Boss 250 not charging
Hey guys,
Need some advice to start digging into. Hooked a multimeter up at the battery since it has gone dead after using the lights. I charged the battery then hooked the multimeter back up. WIth engine off, I was getting 12.6 volts. With engine running I was getting 12.45 volts. I took the fuel tank plastic off the left side to access the wiring panel and hit the alternator output blocks and both were registering anywhere between 2 and 3 volts but no charge at the battery. Any ideas?
Old Mar 3, 2007 | 06:03 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like the recifier is bad, but its just a guess. maybe unhook it and check b4 and after while its running to see any differnce. just an idear.
Old Mar 3, 2007 | 06:06 PM
What votlage output should I be getting at those alternator output blocks in the wiring panel behind the left side tank plastic?
Old Mar 3, 2007 | 06:14 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
w/out a book i wouldnt know, but maybe some of the guys will. should however be getting near 14 or better at the battery when its reved up a little.
Old Mar 3, 2007 | 06:24 PM
That's what I thought too. Thanks for responding.
Shainasmash
May 8, 2017 06:38 PM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
