Grease nipples on Giovanni quads
Old Mar 3, 2007 | 06:56 PM
falco2033's Avatar
Default Grease nipples on Giovanni quads
I just bought my son a 150 cc and when I went to grease the A arms I noticed that the grease nipples that are installed are non-standard size(smaller than standard). Does anyone know what size these are? I was thinking that if I can't find the right coupler for my grease gun I would try and switch out the installed ones for standard size. Has anyone done this yet?
Old Mar 3, 2007 | 07:22 PM
godIlove2ride's Avatar
Welcome to the forums falco. You have two options for these Chinese grease fittings. First there is a needle adapter you can get for your grease gun, it is kind of like a syringe for your grease gun. Use it to push the ball in on the fitting and grease away. Second (this is what I did), you can buy standard grease fittings (the threaded kind not the pressed ones) and replace the Chinese ones. I bought mine at Advance Auto, they came in a package of like 10 assorted fittings. Good luck.
Old Mar 3, 2007 | 08:40 PM
falco2033's Avatar
Thanks for the reply. Does it take metric or standard threads?
Old Mar 3, 2007 | 10:51 PM
The ones I got were standard thread and went in with no problem.
Old Mar 4, 2007 | 10:24 AM
billl2099's Avatar
harbor freight has a metric grease fitting kit , contains enought grease fitting to do a couple of quads, also ace hardware has metric grease fitting.
Old Mar 5, 2007 | 01:01 AM
falco2033's Avatar
Thanks. I swapped out those funny chinese ones for standard ones today.
Old Mar 5, 2007 | 11:06 AM
Did they go in and tighten up okay?
Old Mar 6, 2007 | 08:33 AM
falco2033's Avatar
They went in OK but you have to use short reach ones(only about 3 threads). I had some longer base ones(more threads), and they wouldn't even screw in. The original ones had two threads, and were brass.
Old Mar 6, 2007 | 09:12 AM
billl2099's Avatar
when you shorten the grease fitting by 3 threads did the spring and ball bearing fall out? next time instead of grinding the grease fitting use a small washer as a spacer .
Old Mar 6, 2007 | 12:26 PM
falco2033's Avatar
I didn't grind any down. I found them at my Napa dealer with three threads. I just screwed them in until tight. There was still one thread showing. That is a good idea-washers. I'm going to pick some up and do that. Never thought of that -- [img]i/expressions/face-icon-small-blush.gif[/img]
