bogging down,
Old Mar 3, 2007 | 10:52 PM
TERIOD's Avatar
Default bogging down,
I have a 2003 330 magnum, just starting bogging down on the hi end, i can gain about 3/4 throttle when i roll into it,but when i snap into the throttle it just boggs down and dies , it happens sitting in neutral and moving,
has anybody else experienced this or know what the problem is, i sure would appreciate the help
Old Mar 4, 2007 | 08:37 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
air filter, fuel filter clean?
Old Mar 4, 2007 | 08:49 AM
TERIOD's Avatar
yes and yes, carb cleaned also, noticed wetness around rubber intake manifold, wondering if this would be problem,
other things done
fuel pump test(vacumn)
inverted carb test(vacumn)
pilot idle adj. no help since not idle prob.
electrical testing(seems and acts norma)
Old Mar 4, 2007 | 09:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would clutches would be next, but you say it goes fine when it goes. clutches will make it bog out but usally not in neutral. if it was carb i would guess main jet problem area since you say it idles good and starts off fine. the main jet controlls form 1/4 throttle and up. sorry coudnt give more help.
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
