sportsman 500 temperature?
Old Mar 6, 2007 | 07:25 AM
polarisbear500's Avatar
Default sportsman 500 temperature?
hey gang, how you all been? i was wondering what is the correct temp. my 99 sportsman 500 4x4 is supposed to run? i disconnected the hot light and put that temp gauge in, so i need to know what is normal and what is overheating. thanks, PB500
Old Mar 6, 2007 | 01:27 PM
SCRAMMYTODD's Avatar
I would sat that 180- 200 would be about normal. I think the fan will come on at about 190, but I'm not 100%
Old Mar 6, 2007 | 01:38 PM
brutus450's Avatar
hey bear500 - you say you used the hot temp lead wire? does that eliminate having to install a new temp sensor? I would like to put in a water gauge but I didnt want to tap into anything but if I can just use that wire - that would be awesome.
can you tell me how you did it? I never installed one.
Old Mar 6, 2007 | 02:16 PM
bombaman's Avatar
I have a gauge in my 06 500 and I think the fan comes on at 190. I just installed the gauge so I'm not 100% but maybe 95%...
Old Mar 6, 2007 | 05:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
my 800's fan will come will come on about 200 and go off around 185 i think. brutus, i just found a hot wire that was powered thru the key switch to power it. that way it doesnt interfer w/ the pod gauges.
Old Mar 7, 2007 | 12:26 AM
brutus, it's honestly been about 2 years since i installed the gauge but if i remember correctly, i just tapped into the engine block where the factory thermostat was. i simply took the factory one out and installed the one that came with my temp gauge. as far as electrical, i believe i just tapped into any wire that was hot when the ignition was on and that is what powered it. i am sure some of these guys on here have done the same thing and can tell you exactly how to do it. or do a search for adding a temp gauge, there are some very knowledgable people on here that will help. good luck- PB500
Old Mar 8, 2007 | 12:36 AM
Indyguy's Avatar
I think disconnecting the stock temp sensor would be a big no no if it's an EFI.
I've put these things on mine and am real happy with them. http://www.quadovator.com/902058.html
Had some minor fogging issues, but installation is real easy if you have the tap and proper tap drill (1/8" NPT?)
You lose very little anti-freeze doing this (maybe cup or two), and it's really nice to watch the temp if you've been in the mud.
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
ltrmc02
Jul 22, 2015 04:50 AM
