help with front springs
Old Mar 7, 2007 | 08:49 PM
lawnboy2121's Avatar
Default help with front springs
I have a 05 sp700. I have a push bar and a wintch on the front, now the front is to soft. I was wondering what the best wey to stiffen up the front is.
Old Mar 7, 2007 | 09:30 PM
JCDEYO25's Avatar
lawnboy.....
Check here.....This is where I got mine....They worked out great for me.....Get the heavy duty ones......
https://www.erlandsonperformance.com...gory_Code=susp
John
Ut oh......I see you have a lift in the front.....Not sure but call EPI and ask them.....
Old Mar 7, 2007 | 11:04 PM
superintendent's Avatar
Hey, I have 93 500 HO sportsman with a plow and a winch. I was experiencing the same problem and wound up purchasing the EPI heavy duty springs and they certainly did the trick. Changing them was not a real big deal, just make sure you support the lower A arm so the CV joint does not come apart, because if it does then the job is a pain!
Good luck
Superintendent
Old Mar 8, 2007 | 10:19 AM
Bytor's Avatar
I replaced mine with the springs from the MV7. Made a world of difference. But as John said, not sure if they would work with the lift.
Old Mar 8, 2007 | 11:42 AM
Toycrazy's Avatar
I used the HL Lift Springs on my 06 500ho, gained 2" of lift and now it sits level, and when I lift my plow the front only sags about a 1" to 1 1/2",my plow is very HD with 17" side scoops, ride and handling is alot better to.
Old Mar 8, 2007 | 08:46 PM
thanks for the replys I thinkI may try the high lifter springs. I remopved the lift in the front so now it is stock
Old Mar 8, 2007 | 09:21 PM
JCDEYO25's Avatar
Hey lawnboy....You could also check these out...
http://www.t-m-2.com/
John
Old Mar 9, 2007 | 10:54 AM
sheepdogMSP8117's Avatar
This is what I did with mine.
EPI Springs
Snow plow
Good luck!!
ghost civic
Jan 15, 2020 07:43 AM
carolinabomb
Jul 26, 2015 08:40 AM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
