lt80 clutch slipping
Old Mar 10, 2007 | 02:53 PM
coreyfatboy's Avatar
Default lt80 clutch slipping
i have a 94 lt 80 that i replaced the drive face unit in last year and it worked good , but now when my son was riding in the snow it started slipping and it also did it one time when i pressure washed it. It seems to me that it might be an issue of water getting to the belt but i don't know where to start looking. Also is there any perfoarmance things you can do to the clutches?
Old Mar 11, 2007 | 01:38 PM
LT80's Avatar
LT80 Expert
Welcome to the ATV Connection forums.[img]i/expressions/face-icon-small-smile.gif[/img]
Water is prolly the issue.
You can remove 2 of the 6 rollers to give a lil higher stall speed.
Most clutch mods don't work till there is a modded motor to run them.
Old Mar 26, 2007 | 11:47 AM
daquadfather's Avatar
I'm sure water is getting on the belt.
Check all of your allen keys around the transmission unit. Make sure they are all present and tighten if necessary.
Probably you're transmission gasket has either perished or is not aligned correctly with the seating.
This will allow water to get in. Usually if this happens after pressure washing, a little use and the bike is fine again.
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
jbrewster94
Sep 23, 2015 04:16 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
