Help prob with 650
Old Mar 10, 2007 | 10:33 PM
Strikeswiftly's Avatar
Default Help prob with 650
I guys, I have a friend with a 03 Prarie 650 4x4. All I know is when I put my kfx 700 in reverse and mash it, unless you got that button mashed u dont move very much, like its a shut off. Well my friends got this problem in all gears. Put it in D and hit the gas it will cut out at pricisley the same time it does in reverse. IT does that no matter what you do. Could this be a big ole problem or is it something I can work with?? Just askin maybe someone has had this simliar problem. thanks
Old Mar 11, 2007 | 08:24 PM
mizer's Avatar
sounds like it is in limp mode. check the dash to see if it is flashing 2wd/4wd.if it is take off belt cover and reset switch.than reset dash by switching plugs (black to gray /gray to black and than turn key on./off and stwitch plugs back
Old Mar 12, 2007 | 01:13 AM
Thanks my friend
Old Mar 12, 2007 | 02:30 PM
Hayashi's Avatar
Flashing 2/4WD does not put quad in the limp mode.
Flashing Belt Light does.
BigCam
Sep 16, 2015 01:53 AM
toonces
Aug 5, 2015 05:55 PM
southbayman
Jul 24, 2015 09:30 AM
Dabears1983
Jun 23, 2015 04:59 AM
Fijit
Where to Ride
Feb 6, 2000 01:01 PM
