Help adjusting 110cc CVT please
Old Mar 12, 2007 | 12:25 PM
MPK123's Avatar
Default Help adjusting 110cc CVT please
Hello, my sons chinese Gio 110cc ATV with CTV transmission is not operating as well as I would like. My son from a dead stop can not climb a 4" rut unless he gives the ATV 3/4s full throttle. When the clutch finally engages it shoots him forward as soon as he clears the obstacle. He has the same problem when trying to start on a hill. His 4spd manual transmission 50cc would usually just crawl over a similar obstacle or up a hill with little throttle. What sort of adjustments should I be trying to make to give the bike more starting torque? I have heard about different clutch weights and clutch spring weights but have no idea as to what I should be looking for or where to get them. Thanks
Old Mar 12, 2007 | 05:47 PM
billl2099's Avatar
are you talking about giovanni 110? they do not have a cvt transmission, its just like all the rest of the chinese 110 atv's ,it uses a single speed with a centrifugal clutch. about the only change to make it a little better is change the counter shaft spocket 1 tooth smaller, that will help increase bottom end a little it will also take away some top speed.
Old Mar 12, 2007 | 07:06 PM
MPK123's Avatar
The bike I am asking about is the "110CC GIO MINI HUMMER QUAD ATV" I have not actually taken the case sides off to look but in the item description on Ebay they mention that the Transmission is a CVT. The bike does appear to shift. Correct me if Im wrong but I believe the CVT transmision is mated to a cenifrugal clutch.
Old Mar 12, 2007 | 08:03 PM
billl2099's Avatar
a cvt trans uses a variator ,drive belt, clutch. your atv only has a clutch, i seen your atv on e-bay and they are the basic 110 engines used on sunl, kazuma,redcat and so forth. you do not have a cvt transmissiom.
Old Mar 12, 2007 | 08:08 PM
mrj's Avatar
mrj
Maybe I can help you since you have helped me. I downloaded the manual from the Ebay site for the Allstarz sales for the 110 mini hummer and it gives a decription of how to adjust the CVT transmission on page 110 of the manual. The manual is from a 50cc but I think it is the same engine and hopefully the same transmission. If you have an email that I can send a manual file to I can send it to you.
MrJ
Old Mar 13, 2007 | 01:11 AM
MPK123's Avatar
Thanks MrJ, I dnloaded the manual however I think the 110 is a fair bit different than the 50 in the manual. I will take a look this week and try to determine actual type of trans/clutch. Cheers~
Old Mar 13, 2007 | 09:01 AM
billl2099's Avatar
50-110cc engines are all in the same engine family, only differance is bore and stroke. shares everything else
Old Dec 27, 2010 | 08:23 AM
andertonforza's Avatar
do you happen to have the link for that manual dowload, I can't seem to find it
Old Dec 27, 2010 | 09:51 AM
LynnEdwards's Avatar
Electrical Expert
Which manual are you looking for? Does your quad have a CVT? What is the brand and engine size?
The discussion above is about two different engine classes.
Old Dec 27, 2010 | 01:02 PM
it's a giovanni 110cc mini beast. It says it has a cvt but I think it it just like a snowmobile type setup
