Need help! Kawasaki 250 Bayou
Old Mar 13, 2007 | 09:02 AM
PeNnYlAiN's Avatar
Default Need help! Kawasaki 250 Bayou
I have a new Kawasaki 250 Bayou ATV, had it for about 2 weeks and was wondering if anybody knows how long the drain hose should be? The drain hose on this one flips on the drive shaft rubber boot and gets gas all over it. The air filter also has gas all over it. It seems like at times the gas cap holds pressure in the tank because when you open it you can hear the pressure release. Is this normal with Kawasaki ATVs?
Old Mar 13, 2007 | 09:18 AM
diggerdeep's Avatar
Try to realign your drain hose and ckeck your vent line to see if it is plugged. GOOD LUCK ! ! !
Old Mar 13, 2007 | 11:03 AM
Hayashi's Avatar
If your 250 runs fine, the length of the drain hoses don't matter. Just make sure they point toward the ground. However, you said the air filter is soaked with gas which may indicate your check valve on the fuel tank vent system is clogged or the check valve is installed backward. Another possibility is that you may be running the quad with choke ON or the choke lever is at OFF position but the choke plunger is sticking and it's allowing extra fuel in. The term choke is mis-leading in your bike because there is no choke plate to choke the carb. It is actually an fuel enrichener. So, check the choke plunger at the top of the carb for any sticking.
Hey, it's only 2 weeks old! Take it to the dealer you bought from.
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
