Predator jetting
Old Mar 13, 2007 | 04:07 PM
shepherdblake's Avatar
Default Predator jetting
Anyone know a good jet to run at the walden sand dunes in colorado with a stock 2003 predator with pure polaris pipe?
Old Mar 13, 2007 | 06:53 PM
Bradracer18's Avatar
What makes you think you need to change jetting.......from where you are now? Please explain......and we'll try to help
Old Mar 13, 2007 | 07:12 PM
I'm in Longmont Colorado at about 5K feet. I bought my preddy used from a dealer. It was raced at the tracks nearby and is setup PERFECT for about 5K feet.
Walden Sand Dunes are about ~8-9 K feet.
thanks for any help!
Old Mar 13, 2007 | 11:42 PM
scrammersam's Avatar
im pretty sure that if you take a few discs off the pp pipe it will change it so you dont need to rejet
Old Mar 14, 2007 | 12:52 AM
I've thought about doing that......
Maybe I will try it.
Last season when I had it at the dunes, it needed a little help, hence the question.
thanks!
Old Mar 14, 2007 | 03:11 PM
I'd think the disks would do it.....if not.....just get a jet above, and below what you are running now(I'm not sure how altitude affects jetting)......so then you can adjust it, while there.....doesn't take but about 10 min.
Old Mar 15, 2007 | 03:34 PM
heater's Avatar
Bradracer
Ive got a couple year old preddy. The only way it will run is with the choke on.
I took the carb apart last nite cleaned it out, blew air though the jets. back together, same problem. Any suggestions?
Old Mar 15, 2007 | 03:39 PM
crazy1291's Avatar
well then your jetting is whacked, heater. just buy a jet kit and you'll even notice a slight improvement over stock power.
Old Mar 15, 2007 | 03:54 PM
I disagree........could be you jetting......where do ya live(like close to sea level?)......and what jetting are you running(and what mods do you have).
Also.......try to join www.predatorowners.com Ask there.......its a great site!!!!!!!
Old Mar 15, 2007 | 03:58 PM
heater's Avatar
Elevation is 800 ft.
No mods, all stock
