Breakers
Old Mar 13, 2007 | 09:09 PM
waldo238's Avatar
Default Breakers
I have a 2004.5 polaris sportsman ho and for the life of can not find them to see which one is bad. I have a picture of under the hood if you need to see it. Everything I have seen say's they are in 2 little sealed pouches, this bike has no sealed pouches. I have ripped the whole cover off the front of this thing and NOTHING!.
Old Mar 13, 2007 | 09:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Breakers
im assuming you mean a 500 ho. there is a fuseable link inthe battery line i beleave.
Old Mar 13, 2007 | 09:38 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Breakers
What is your problem to begin with????
As for breakers....I would say NO!!!! fuses or fusable links maybe...
Do you have the wiring drawing for that quad?
Follow the 12 volt power wire back through the drawing and go from there!!!!!
See where you loose power (12-14 volts).....
Who told you about these 2 little pouches???...Were they talking about links......Caper.....
Old Mar 13, 2007 | 09:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Breakers
some bikes have resettable fuse/circuit breakers or links. they all do about the same thing i beleave. i cnat see them in the wiring harness on the web page but it doesnt break down what is what either.
Old Mar 13, 2007 | 09:51 PM
waldo238's Avatar
Default Breakers
Yes it is an HO. I had to replace my CDI box. After doing so I still have no power. I know you are thinking why replace it. Trust me it was smoked. I have also traced the battery wires and I don't see anything that looks like a fusible link.
Old Mar 13, 2007 | 10:14 PM
Default Breakers
Was that Box ........"A Sure Power Industries, Inc." This is black and has some Heat Sinks on it for cooling? ............Caper.........
Old Mar 13, 2007 | 10:16 PM
waldo238's Avatar
Default Breakers
No, this was an OEM rreplacement CDI box. No heat sinks, solid black and a rubber looking coating on one side. There is a part that has cooling fins on it under the hood but that was not smoked. I just need to find the fusible link and see if it is bad.
Old Mar 13, 2007 | 10:33 PM
Default Breakers
When you say "SMOKED" do you mean just no good, damaged, or actually went up in "SMOKE"...Caper................
Old Mar 13, 2007 | 10:39 PM
Default Breakers
O.K. here is another tip for you to try............
Take the RED power wire "off" the battery.....Then with an OHM meter(set to Ohms) check the end of this wire and the other to ground (frame).........If you have a beep or reading in OHMS.........There is a DEAD short somewhere..........This may be the reason you have no power............When you say "SMOKED" that scares me (I am A Electrician)..LOL..LOL.....Caper...........
What is your battery voltage when the quad is just sitting there??????
Old Mar 14, 2007 | 12:02 AM
GarryESE's Avatar
Default Breakers
Your machine has a box under the hood that controls way too many things; voltage regulator, rectifier, circuit breakers, safety switches, hot light, fan, etc, etc. The 2004.5 sportsman are bad for curciut breakers failing in these boxes. The box has ribs/cooling fins on it and is located under the hood. It is about 6"X4"X1". It has 2 or 3 wiring plugs on it; one of which has 12 or more wires on it. If I recall correctly one plug has three yellow wires (charge coils from the stator.)
