shifting problem?
Old Mar 14, 2007 | 09:18 PM
hammertyme's Avatar
Default shifting problem?
i have a shifting problem on my raptor 80.most of the time when i shift up into 2nd or 3rd it goes into nutral for a little bit.Can anyone help me?
Thanx for replys
Old Mar 14, 2007 | 10:04 PM
godIlove2ride's Avatar
Is it possible you are holding the shifter up a little long. If you hold the shifter up, the clutch is engaged.
Old Mar 15, 2007 | 07:06 PM
hammertyme's Avatar
no that aint it
Old Mar 15, 2007 | 07:50 PM
MPK123's Avatar
I dont own a Raptor bike but I was just curious if the raptor is a maual shift with an auto clutch. With a couple of my ATCs I have experienced a similar prob where I would let off the throttle, shift then give it gas and it feels like it slips for a while then engages. To fix this problem I adjusted the clutch.
Old Mar 15, 2007 | 08:05 PM
I automatically assumed being an 80 it would be an autoclutch.
Old Mar 15, 2007 | 10:01 PM
hammertyme's Avatar
yes its has a auto clutch and manual shift.and ya when ever it does that it just slips in nutral for like 6 or 7 seconds then it will shift up
Old Mar 16, 2007 | 05:56 AM
atvingnc's Avatar
hammertyme,
I would tend to agree with godIlove2ride that the clutch is sticking in the disengaged position and that the transmission is not going into neutral when you are shifting. do you notice the shifter sticking or binding in the shift position after you have shifted. if you do not notice the shifter sticking it could be the push lever mechanism (auto clutch) on the inside of the engine stator cover. even if the shifter returns to its unshifted position the push lever mechanism could be sticking and causing the clutch to remain disengaged. I would recommend removing the engine cover on the shifter side (shouldn't take very long) and checking the push lever mechanism. It could simply need lubricating. Has the auto clutch been adjusted. you could try loosening the nuts that hold the auto clutch adjusting screw and turning it slightly. the scew adjusts the push lever mechanism. if the screw seems difficult to turn it could indicate a push lever problem. I would recommend getting an engine cover gasket before you remove the cover as its hit or miss on whether the gasket survives the cover removal. look on any of the web sites where you can buy ATV parts and most have an exploded views of the different components (www.worldofcycles.com). select the clutch view and you can see the mechansim.
Old Mar 16, 2007 | 04:13 PM
hammertyme's Avatar
ya i was thinking of takeing off the shifter side to see whats up.
i do think my clutch is going bad
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
