How to gear 90cc Chain Drive lower?
Old Mar 17, 2007 | 06:50 PM
jettman's Avatar
Default How to gear 90cc Chain Drive lower?
I just bought a SunL Atv 109, 90cc. It is a chain drive and seems geared too high. Is it possible to just put a different sprocket on? If so, please be specific on how to do this. I am rather new to Atv's.
Old Mar 18, 2007 | 10:11 PM
MoparRob's Avatar
I'm guessing it is the honda clone engine. You need to remove the front sprocket cover on the left side of the motor. If it is uses a six spline sprocket. The front sprocket from a 98 honda z50 should fit. The run all of $14. You can get them from 12 to 18 tooth. I use a twelve on my daughters yamoto atv, yours is probably a 14. It did make a difference with the low end. If this sprocket is correct then you also have a 420 chain. You may have to shorten the chain. You can always just add a second master link to it. I haven't seen a 90cc yet that can break a chain whether it has two master links or one.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Ramman1
Jun 16, 2016 09:07 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
tporath
Jul 11, 2015 12:31 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
