Oil Light Flashing Unison Desert Cat 90
Old Mar 18, 2007 | 12:37 AM
HTELectrical's Avatar
Default Oil Light Flashing Unison Desert Cat 90
The oil light on my son's brand new DC 90 (only one tank of gas) is coming on intermittently. It happens at the same speed basically. I took it for a ride down the street and noticed that it comes on at about 15 MPH, and will go out at about 20. It does it whether I gradually accelerate or give it full throttle. How does the oil light work? Does it measure oil level or actual oil being supplied to the motor? I am hoping that this isn't going to be a problem, because we are going out riding tomorrow morning. Any info would be appreciated!!!!!!!
Old Mar 18, 2007 | 12:29 PM
2manytoys's Avatar
It measures oil in the tank. there is a sensor in the oil tank. Is the tank full? How is it doing so far. Have not heard from you in a cpl weeks.
Old Mar 20, 2007 | 12:50 PM
Good. I have been slammed at work. Haven't been able to go out riding the last couple of weeks. Went out on Sunday for a few hours. ATV is running good! The only complaint (besides the oil light) are the tires. My 700 will climb just about any hill in 2wd, even if I stop midway and take off again. The 90 which is considerably lighter digs in, if the sand is soft. Do you have any suggestions for a better tire?
Yes, the tank is full. I found a couple of posts about the Predator 90 oil light flashing when the restriction was removed. Basically the same circumstances. Are you sure it doesn't measure pressure? I don't know why it would come on in the same throttle/speed range all of the time, and not come on at full throttle.
Thanks again for your help!!!!!
Old Mar 23, 2007 | 06:02 AM
Bump
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Sep 2, 2015 11:15 PM
