diff lock
Old Mar 18, 2007 | 09:34 AM
foreman500es's Avatar
Default diff lock
i just bought a new 500 foreman es, i was just wanting to know if u could buy something for the front diff, ie[ diff locker ] thanks
Old Mar 18, 2007 | 09:41 AM
wildwest1011's Avatar
Default diff lock
Check out 'Detroit gearless locker', I know they make some lockers. Try google or maybe highlifter.com
Hopefully someone that knows more will chime in.
Old Mar 18, 2007 | 10:41 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default diff lock
You should ride it a while and see how it does, before rushing out and getting lockers. You may find you don't even need it......
Old Mar 18, 2007 | 11:14 AM
mykool61679's Avatar
Default diff lock
300.00$$$ you can get a detriot gearless locker. it also makes it easy to turn, not like a spool locker(30.00$), which will build that chest up!! both function the same, keep all fours spinning in any situation, ones alot cheaper, but alot harder to turn. the cheap fix is tapping the front breaks, this will make the tourque sensing differential spinning both tires!!
Old Mar 18, 2007 | 11:33 AM
Default diff lock
thanks for the info, i know the bike is new but like all guys got to make it better
Old Mar 18, 2007 | 10:30 PM
ForemanDan's Avatar
Default diff lock
I have not found the need for one since I have been riding. Try it out first.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
John Reed
Sep 9, 2015 03:46 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
panicmanic
Aug 25, 2015 09:10 AM
