LT 80
Old Mar 19, 2007 | 02:37 PM
RABDAB's Avatar
Default LT 80
My daughers 2000 LT 80 no longer has the power to pull hills. Dose the belt have adjustments or do they stretch over time. Should I replace it ?
Old Mar 20, 2007 | 10:09 AM
LT80's Avatar
LT80 Expert
Default LT 80
The belts last forever. The used ones actually work better than new. No adjustment. The belt isn't the problem here.
I'd check the compression.
Old Mar 20, 2007 | 10:45 AM
RABDAB's Avatar
Default LT 80
the reason i think its the belt is because when pulling the hill it starts to slow down and you can hear a whine start. it almost sounds between a whine and squeal. kindof like a lawnmowers belt slipping.... thats why i think its the belt not sure though... any ideas?
also when i took the cover off to look at the belt (like where the pullstart should be) i noticed it had a groove in it where it was wearing faster on one place or somthing.... is it normal?
Thanxs
Old Mar 20, 2007 | 01:58 PM
LT80's Avatar
LT80 Expert
Default LT 80
Yes that's normal. It's prolly wearing from the big washer that's in there.
I think you should pull the sidecover and service the clutchs. That may tell us alot.
Check for flat spots on the rollers and rear clutch bearings.[img]i/expressions/face-icon-small-smile.gif[/img]
