Would you have bought this?
Old Mar 20, 2007 | 08:17 PM
GrizzlyJim's Avatar
Default Would you have bought this?
Ok so I just bought a "new" 2005 Brute Force 750i for $5,099, no set up or anything just tax which came to like $5,500 give or take. Here's the catch though, it was the machine they parked out in front of the dealership ever day, it has 2 miles on it and 7 hours. Do you think I did ok? or is this thing going to be an oil burner? It's probably not the best break in circumstances, what trouble could I have with it if any? Yes it does have the new tie rods on it too. Wondering if I should get an extended warrenty on it or not??? Thanks for the help!
Old Mar 21, 2007 | 07:34 PM
montyh's Avatar
I think you did good. first, i'd change the oil. then take it out and give it a very long hard run to seat the rings. i wouldn't worry about the extended warranty unless you would do it anyway. i pretty much voided my warranty the first couple of days i had mine. no problems at all, tho.
monty
Old Mar 21, 2007 | 09:20 PM
hikuntryslim's Avatar
would i have bought this ........no
Old Mar 21, 2007 | 09:33 PM
ridnMT's Avatar
yes, you got a good deal. Check the belt deflection and change all the fluids. I would get the warrenty, better safe than sorry, just hope the dealership will honar it. Heard some peaple were having problems with that.
Old Mar 21, 2007 | 10:06 PM
guzzler2's Avatar
I think you did OK. With many recommending the "break it in like you drive it" stuff, I wouldn't think that much about the test drive hours. I agree with Monty, change the fluids before you use it. I would also change the engine oil again after you give it some hard riding to seat the rings.
Don't forget about the buss connector fix...much easier to protect the buss with grease or solder the wires before the problems start.
Congrats!
Old Mar 22, 2007 | 11:04 AM
frotrk's Avatar
the dealer probably just did not turn the key off when they moved it around. hour meter counts when key is on even if engine is not running.
Clark
Old Mar 22, 2007 | 11:25 AM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
If your happy and it makes you smile when you ride it, you got a good deal. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 22, 2007 | 12:08 PM
squeege's Avatar
I would ask if they could write on your bill of sale that the quad was sold with 9 extra hours on it......same goes for if they leave the key on during work performed on the quad....course if you plan on keeping it Who cares..........
Old Mar 23, 2007 | 02:37 PM
Quadmiester's Avatar
Personally I think you got a good deal. Like everyone elses says, change the oil after a couple hours. I would definately get an extended warranty for it. Not because it was a showroom queen but because I think the extended warrantee is a good thing to have on a quad. Mine has paid for itself.
Old Mar 23, 2007 | 08:01 PM
GrizzlyJim's Avatar
Thanks for all the help. I picked it up last night and checked everything over when I got it home. The air filter was pretty dry so I oiled that and made sure all the fluids were up and checked the front plug, looked kind of black. I'm going to take it out for a ride tomorrow and then change all the fluids and put new plugs in it. Does the front diff really take 10W-40 motor oil? I know the rear takes wet brake fluid. Thanks again.
