a couple questions about meerkat 50cc
Old Mar 21, 2007 | 12:41 PM
fink's Avatar
Default a couple questions about meerkat 50cc
does anybody know the ngk sparkplug number for this quad
and also what is the spark gap on this quad
has anybody had a problem with the gas tank neck cracking ive bought 2 gas tanks and both did it
I appreciate your time!
Old Mar 21, 2007 | 02:13 PM
fink's Avatar
ok i found the ngk # any comments on the other two questions
Old Mar 21, 2007 | 02:49 PM
godIlove2ride's Avatar
fink,
I can't tell you what the gap should bem but my tank neck cracked as well. I fixed mine so that it would never do it again. I emptied the tank and cleaned around the inside of the neck. Then I mixed up some JB Weld and coated the entire inside of the neck with it. Gives the neck another layer that will not crack. Never had another problem again after that. You can get JB Weld in tubes at Lowes/Home Depot or your local hardware store. It's good stuff.
Old Mar 21, 2007 | 04:09 PM
fink's Avatar
thanks a lot i will try that
one again thanks alot
ill tell you how it goes
Old Mar 21, 2007 | 05:03 PM
billl2099's Avatar
gap .028
Old Mar 21, 2007 | 10:29 PM
fink's Avatar
Thank you very much for the correct gap billl
hey godilove2ride did you put that jb weld on the inside or around the outside
and if you put it in the inside you never had problems with the gas dissolving it?
Old Mar 22, 2007 | 08:25 AM
I coated the entire inside of the neck, and gas will not dissolve the JB Weld once it's cured. I used the JB Quick Weld that cures in a few hours.
Old Mar 22, 2007 | 02:35 PM
fink's Avatar
sweet thank you very much i tryed the jb weld fix and it worked like a champ i (and my wallet )appreciate the advice[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 22, 2007 | 05:35 PM
JD4020's Avatar
we've got 2 - 50 cc kazuma's that had the same gas tank problems........ I think I will try the JB Weld trick also.......
Jon
Tomtom86
Aug 7, 2024 07:40 PM
Ramman1
Aug 11, 2022 01:53 PM
Kyle5050
Dec 13, 2019 04:25 AM
toonces
Oct 16, 2019 12:11 PM
firsttimerider
3) General Discussions..
Aug 9, 2015 09:54 AM
