2004 kawasaki prairie
Old Mar 23, 2007 | 06:24 PM
fu250's Avatar
Default 2004 kawasaki prairie
i have owned this machine since brand new. service right when i should the works! last weekend i flooded it in the river. i pulled the wheeler out of the water drained all the water let it sit and dry over night(about 24hrs) the next day it fired right up and it ran great for about 5 hrs. brought it home washed it up and the next day it wouldn't start. i changed the plugs only to find out that i'm getting no spark. is there something else i should be checking? actually i'm at a lose and don't know what to do next. any info would be great thanks guys.
Old Mar 24, 2007 | 07:37 PM
Kawi650's Avatar
I take it you are aware it starts only on one cyl. Things I would look at is : switch plugs back, check for water in the cap, also look at that flipping censor in the back to see if water is still in there. Also when the plugs are out pull start it and see if crap comes out the plug holes. You might find after you get spark there's water in your fuel.
Old Mar 25, 2007 | 02:44 AM
fu250's Avatar
sorry new to all the terms..... what and where are the switch plugs back? cap are talking about the two coils up front? and the flipping thing what is all that? thanks for your help bud.
Old Mar 25, 2007 | 09:29 AM
Kawi650's Avatar
Put your old spark plugs back in. The caps are the plastic things on the top of the spark plugs. The flipping sensor is a small box under the rear right fender... be carefull in identifing it, it's not the one with what looks like ripples on it. Did you also try pull starting it? The main fuse under the seat could also be dirty. it's in a small red box not the yellow white one.
ReconBayou
Oct 16, 2019 02:24 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
