Kazuma Mini Falcon Oil Change ?
Old Mar 25, 2007 | 01:47 PM
FOWL444's Avatar
Default Kazuma Mini Falcon Oil Change ?
I just purchased a Kazuma 90 Mini Falcon Deluxe and need to change the shipping oil . The Book says the plug is the 17" at the bottom but that plug will only come out so far then it hits the frame . The 14" screw will clear but I dont want to take it out if it isnt the oil plug .
Any Idea's which plug is right ?
Old Mar 25, 2007 | 02:47 PM
dealseaker's Avatar
17mm one I think, maybe try to get it around the frame somhow
edit, may have to lift the engine up some, haven't heard of this problem though. It should not be hard to lift it up the amount u need, just take the bolt loose and lift it up, drain oil, put it back together, maybe an extra 10 min or so of work.
Old Mar 25, 2007 | 08:01 PM
FOWL444's Avatar
Thanks for the quick response and I did what you said and it worked .We had to loosen the 4 bolts on the bottom of the unit and lift the engine just a bit to get the plug out because the frame was blocking it .
It worked but what a odd place to put and engine drain ..they should really look into moving that .
Old Mar 25, 2007 | 09:49 PM
tsdgoes's Avatar
do not take out the one by the frame. It is the 17mm one to change the oil. The one on the right side.
Old Mar 26, 2007 | 12:49 AM
FOWL444's Avatar
The 17mm screw is the one that lines up directly under the frame and almost came out but needed that little bit more room that was why we had to lift the engine a bit
ReconBayou
Oct 31, 2022 05:37 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
