Kazuma Dingo 150cc vs. Jetmoto Hunter 150cc
Hello All,
I am very interested in the Kazuma Dingo 150cc ($1,500) but now I have found a Jetmoto Hunter 150cc ($1,700). They both use the GY6 Honda clone engine. I have heard the Jetmotos are a bit better quality than the Kzaumas but at the time the only utility quad I saw from Jetmoto was the 250cc Hunter ($2,500) and it was too expensive. I am not sure if things really change now that I found a 150 Jetmoto utility quad.
Dingo:
352 lbs.
Wheelbase 43"
Hunter:
495lbs
Wheelbase 47"
Does anyone know the major differences other than those I listed? What about quality of these two? The Hunter is much heavier I think. With the same engine that would slow things down, but is that because the quality of the frame is that much better?
Thankx for you input,
Dr. Ffreeze
Dingo:
352 lbs.
Wheelbase 43"
Hunter:
495lbs
Wheelbase 47"
Dr. Ffreeze
2manytoys,
Thanks for the fast reply! I weight about 150lbs (5'11"). How would a heavier quad (with the same engine) pull me around better? Is it because of the tire size or wheelbase? Sorry I don't quite get it.
Thankx again,
Dr. Ffreeze
Thankx again,
Dr. Ffreeze
DrFfreeze,
Have you seen the Shinima Bushman? It's in the same price range with a few more Cc's. Here is a thread where another forum member just purchased his. Shinima Bushman
If your looking for a quad with the CVT trans the Jetmoto is a choice.
Good luck with your purchase.
SB.
SB.
It may pull about the same but I think an adult would be more comfortable on the JetMoto. Plus the JetMoto is made better. I really have not heard anything bad about the Dingo either. I think the JM looks better also.
Elkaholic
Sep 6, 2015 02:44 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
