90 meerkat no spark/no start/ kid crying
Please help,
Just uncrated my sons meerkat 90. Charged battery, drainded oil and refilled, fuel up.....No start.
So far I have fuel, and juice to cranck...but no start.
I pulled the plug and check for spark nothing.
Took out plug and tried with screwdriver still no spark....We have atrip planned leaving tomorrow PM. The Kid is crying.
PLEASE HELP!!!!!!!!!!!
JOHN IF YOUR OUT THERE I NEED SOME HELP. I"M IN CALI. TWO MILES FROM YOUR WAREHOUSE OUT HERE>>>>>
Attila
Attila
Might want to check all saftey features... Kill switch/emergency cut off switch in back of quad.(the switch you attach a cord to) Sometimes the saftey cut off switch gets bumped/or isn't making good contact. This will cause "No Spark" I bumped my son's when unloading it from my truck.. Then spent like 30 minutes trying to start it Until I finally realized the switch was moved... At first inspection it looked ok, until I pushed in on it... I really hope that helps you out!! Keep us posted!!
Like triple said check ALL of the safety switches. The one on the left part of the handlebar has one. The red switch goes left or right to turn bike off. You have to press the same button in to reactivate it. There is a shutoff on the left side of the motor. It is a white connector with a small looped wire. This has to be there or it will not start. On the back left of the quad there is a tether switch. This should have the rubber plug in. Or to eliminate this one you can just unplug it from the harness just under the rear fender.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
sweaver
11
Aug 18, 2015 03:47 PM
Aug 6, 2015 11:49 AM
