Warrior Sprockets
Old Oct 13, 1999 | 12:58 PM
hot_shoe_cv's Avatar
Assuming the rear tires are the stock 22"height, the 14/40 combo would give you a slightly slightly taller gearing, meaning a lower ratio. If you're running 20" tires, however, as I am, then of course the shorter gearing would pretty much get you back to stock gearing. Based on the foregoing assumption, I'd go with the 14/40 setup for slightly more on top & slightly less at the other end, which you easily afford unless you are pulling stumps.
Sprocket changes is much like life itself..
mostly give and take
save your riding area! join the Blue Ribbon Coalition online @www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 10-13-1999).]
Old Oct 13, 1999 | 12:59 PM
Heapster's Avatar
I agree on the 14/40 reccomendation. I tried running a 15/40 with similar basic bolt-on mods, and the warrior didn't have enough poop to pull that high a gearing.
After my 400cc bored/stroked/cammed/ported engine mods, I CAN pull a 15/40 very easily for logging roads, but haven't tried that gearing in the dunes yet, where I may drop back down to the 14/40 combo.
Heapster
400cc wicked warrior
Old Oct 13, 1999 | 02:10 PM
dunc_n's Avatar
I have a modified '94 Warrior with stock 13/40 gearing. I really like the bottom end and midrange power but would like to gain a bit on the top end. I have a 45 tooth sprocket for the rear. My question is which will give me the most top end while not taking away a noticeable amount from the bottom end? 14/40, 15/40, or 13/45? I would have to buy the 14 or 15 tooth front sprockets but I already own a 45 tooth rear. I mostly ride in trails, with hillclimbs, rocks, hardpack, and the occasional fire road. Sometimes I ride with a Banshee so a little gain in top end would be welcome. Still wouldn't trade my Warrior for anything. Much better trail quad than a Banshee. Thanks in advance.
Duncan Currie
'94 Warrior w/K&N Filtercharger, Jet Kit, Supertrapp Racing Series
Old Oct 13, 1999 | 02:34 PM
kevhog's Avatar
The 14/40 would be your best bet. The 15/40 would be like dropping 5 or 6 sprocket sizes in the back, and the 13/45 is going to kill your top end, not help it. Take your rear sprocket number, and divide by the front number. This will give a good idea of the ratio you'd be running, and you can kind of compare it to gearing in a car. The lower the number, the higher the higher the top end, and vice-versa.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
