110 loncin powered roketa questions
Old Apr 2, 2007 | 10:08 AM
retics4me's Avatar
Default 110 loncin powered roketa questions
It starts fine but seems to choke off when you give it gas if you dont let it warm up for a long time. Even then it will sometimes when you give it gas . Also I would thing that it would have more low end power. My son is like #40 and it wouldnt go up a hill I had to push him. We were playing in some mud and he couldnt spin the tires off the line ? It seems it takes awhile to rev up . Does anyone have any suggestions? The guy/dealer I bought it from is a dipchit .
Thanks
Old Apr 2, 2007 | 10:25 AM
cowgirl's Avatar
Is it a full auto or semi, if it is a full you can buy an 11 tooth front sprocket from Redcatmotors.com and change it, it will give you more hole power been there done it. They may have it and they may not they are very lax on parts anymore. This is for the power part don' know about the warming up part.
Old Apr 2, 2007 | 01:01 PM
retics4me's Avatar
sorry its full auto
Old May 29, 2007 | 02:17 AM
Vitals2k's Avatar
Retic....I have a Roketa Go Cart semi auto loncin 110cc....mine was doing the same thing....I found the problem to be the fuel line.....the techs routed too much slack in the line (before & after the filter)....I cut out about 4 inches above the filter to the tank....& 2 inches below the filter to the carb.....runs very strong now.....its a 3 speed w/rev........I am 240lbs & it does 32-33 mph with me in it......perfect for my kids....also make sure you tighten all the bolts & change out screws to bolts with lock washers.....makes it much more secure & will last longer
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
