FRONT DIFFERENTAL OIL HOW MUCH & TYPE?
Old Apr 4, 2007 | 02:33 PM
JTSKIR222's Avatar
Default FRONT DIFFERENTAL OIL HOW MUCH & TYPE?
I HAVE A 2005 BRUTE 650 AND I TOOK OUT THE AXLE TO REPLACE A BOOT. THE OIL FROM THE DIFF ALSO CAME OUT. I DONT HAVE A MANUAL FOR THE BIKE SO I WANTED TO KNOW HOW MUCH OIL TO PUT BACK AND WHAT TYPE??
THANKS IN
ADVANCE
Old Apr 4, 2007 | 04:46 PM
Hayashi's Avatar
10W-40 motor oil (preferably synthetic) about half a quart or until it flows out of the fill hole.
Old Apr 5, 2007 | 01:25 AM
grizzkiller's Avatar
i heard synthetic oil in the front diff causes the clutch pack to slip when trying to lock it. i'm gonna stick to conventional 10w-40 dinosaur oil.
Old Apr 5, 2007 | 11:52 AM
Hayashi's Avatar
I've had synth oil in my front diff for almost 3 years in my '05 BF and NO PROBLEM what so ever. Even if it slips a bit, I'd rather let it slip than seize the spider gears there. It's your choice.
Old Apr 5, 2007 | 01:05 PM
no, no. if it has been working for you than thats great. this is just something that i read on a forum. i just use the regular 10w-40 because that was in the manual. besides, i change it quite often and tend to fill at a slight angle to get a touch more oil in there.
Old Apr 5, 2007 | 01:17 PM
JTSKIR222's Avatar
thanks for the info guys.
my supermoto bike has a slipper clutch in it and it would not work with full synth oil....
i think i will try the full synth in this and see how it works
Old Apr 5, 2007 | 02:07 PM
tencubed's Avatar
Being retired is a hoot!
Thanks for this info, I have been wanting to use synthetic for some time but have stuck with the dino because of the manual. Time to change to synthetic. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 5, 2007 | 05:35 PM
trailblazermudrunner's Avatar
i have used 8090 gear oil in the front diffs befor with no problem
Old Apr 6, 2007 | 02:52 PM
v2rider's Avatar
use 80-90, or 75-90 Amsoil gear oil in the front and rear diffs of my Cat, and it works great.
Old Apr 6, 2007 | 04:24 PM
ya cant use gear oil in a wetbrake rear diff. ya need wetbrake specific oil(kawi wetbrake, mobil 424, and such). the kawi front diffs call 10w40, same as motor, synthetic or not, your choice. i wouldnt use gear oil in a diff lock setup unless called for.
