Baja 150 & Baja 90
Old Apr 4, 2007 | 05:21 PM
barchamb's Avatar
Default Baja 150 & Baja 90
Recently bought a Baja 150 and Baja 90 from a local PepBoys. Cheap, but fun. Now that we've been riding them for a while, I'm wondering what I can do to them to up the performance a little, if that's even possible on these cheap quads. I especially interested in what can be done to the 150, as when my older daughter is not riding it, that's the one I ride. My younger son rides the 90, so I'm not in too much of a hurry to mess with that one. :-) Any links to any info on these quads would be greatly appreciated.
Old Apr 5, 2007 | 09:57 AM
kansasbuggy's Avatar
which 150 did you get ? extreme or recreation?
Old Apr 5, 2007 | 12:55 PM
barchamb's Avatar
Yeah, I probably should have mentioned that, huh? It is the recreation one, the automatic.
Also, I've been reading some of the threads here and at other places, and they all mention a governer on the 90 that can be disconnected. They all say it's under the rear fender opposite the pipe. I've looked there on my 90, and I don't see anything like that. Did they get rid of it in newer builds?
Does the 150 (recreation) have a governer I can disconnect?
Old Apr 5, 2007 | 05:28 PM
the baja 150 rec does not have a rev limiter on it. a couple things that you can do is put some spacers on the rear axle, it seems a bit narrow. go to a liter tire the stocks are really stiff, unless you ride in rough areas. the engine is a gy6 and there is a lot of gy6 hop up stuff out there
Old Apr 5, 2007 | 05:49 PM
barchamb's Avatar
Thanks. Do you have any links to the spacers, tires, or hop up stuff for the gy6? Any suggestions on what places to look?
Old Apr 5, 2007 | 06:50 PM
just do a surch using gy6 engine, you will find plenty of stuff out there
Old Apr 6, 2007 | 02:36 PM
barchamb's Avatar
What about oil? I know that I am supposed to change the oil after the first 20 miles or so to get out all the break-in junk, but what oil should I use? The manual seems to suggest 10W-30 for my client (I live on the central coast of CA), but the guys at Pep Boys where I bought it said they put in 5W-30. And, I've seen differing opinions on synthetic vs. regular. Any ideas?
Old Apr 6, 2007 | 04:42 PM
I would change the oil right away, just a reguler 10-40, put about 10 hours on it, then go to a 15-40 synthetic oil
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Jul 30, 2015 09:39 AM
