Changing handgrips
Old Apr 7, 2007 | 08:44 PM
coonpelt's Avatar
Default Changing handgrips
Is this a easy job? I see there is some sort of rivet inside that the end cap screw mounts too?
Old Apr 7, 2007 | 11:37 PM
v2rider's Avatar
Very, very easy. Take the screw, and stock handle grip off, and put the new one on. I saved the old ones, just in case. Put some sealant, or NON permanant adhesive on the bar before putting the grip on. I wouldnt use any super strength super glue or anything, as you may want to add different ones, or heated ones later
Old Apr 8, 2007 | 03:37 AM
HR's Avatar
HR
take the cap screw off. then i use compressed ait to take the old grip off and put the new one on, you can use hairspray to hold them in place. (white rain works the best) or they do sell "grip glue" but i wouldn't buy it.
good luck.
HR.
Old Apr 8, 2007 | 12:54 PM
coonpelt's Avatar
Can the old grip be cut off?
Old Apr 8, 2007 | 01:36 PM
HR's Avatar
HR
yes just be careful not to scar the handle bars,
if you have an aircompresser, grab the inside edge of the grip and place the air nosle right between the grip and bar and giver her alot of air and pull and the grip will kinda inflate and come right off. do the same put put new one on.
as for cutting just try not to cut into the handlebars
HR.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
