four wheeler runs but will not go
Old Apr 7, 2007 | 09:33 PM
scotty562's Avatar
Default four wheeler runs but will not go
I have a 220 kawasaki bayou four wheeler that will not go. It runs fine but will not move when the throttle is pushed. Yes, it is in gear. What should i check to fix the problem?
Old Apr 8, 2007 | 02:02 AM
esonnen's Avatar
on the right side of the bike there should be a cover just above and behind the foot-peg, most likely it will have 3 screws. Take it off. underneath that, you should have a flathead screw that is locked in place with a nut. This is your clutch tensioner adjustment. I recommend you consult your owners manual just to be sure, but i'll tell you off of memory how to adjust it. If my suggestion doesnt work, reverse the clockwise/counterclockwise and try it again. Loosen the locknut (leave it on, just nice and loose-maybe a couple of full turns from snug). Using a screwdriver (and taking care not to strip the screw) rotate the screw counterclockwise until it doesnt go anymore. Then rotate it clockwise until it doesnt go anymore. Last, rotate it counterclockwise until you feel tension. Tighten your locknut and put your cover back on. You should be good to go. The other thing that it may be is that the oil you used has a special lube in it that will not allow the clutches to grip, but I have never actually heard of this happening-ive just heard that it is possible with some lubes. I strongly suggest consulting the manual for clutch adjustment, as this is the procedure (if I even remember it correctly) for a lakota sport, which has a bayou 300 engine. I believe that the engines are fairly similar.
Best of luck, let us know if it works!
esonnen
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
Trade3
Ask the Editor
Jun 21, 2015 10:30 PM
BEEFKING69
Jun 17, 2015 12:38 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
