new exhaust on 450r and at full throttle it sputters??
i have a 2007 trx450r and just got a hmf slip on exhaust for it and now at full rev it sputters i changed out the jets with the ones provided with the exhaust itself and it still does it any ideas on what the problem could be
could be they gave u the wrong jets for your altitude.... try jetting it again... did you get an airfilter?? try adjusting your airmixture screw.. or you could mess with the clip in your needle.. raise it up a notch and not rejet..
If you look at the bottom of the carb you will find an adjuster screw which you can use to tune and that should do the trick, just try turning it out about 2-3 turns...Welcome to the forums and let me know how you make out.
well so far as my jets i have a 165 main that they gave me and then a 48 pilot also was given with the exhaust and so far as the adjuster screw i cant seem to find it the only screws i see is the one to open up into the jet compartment and the one that lets you drain the gas out of it that is it??
ok i adjusted the fuel mixture screw and still does the same thing??
Just out of curiosity is you intake tube and filter connected tightly...The adjuster screw is recessed a little bit and I would try messing with the clip positions and see if you get any response like 1988 mentioned...Also what color is your plug reading after you run the bike for a little bit.
