lt 80 low end power problem
Old Apr 9, 2007 | 02:33 PM
rgladen's Avatar
Default lt 80 low end power problem
My daughters 1992 lt80 runs great when I have it up on a jack stand, but as soon as I take it off it wont even pull its self. The motor just boggs down. If I assist it to get it going it runs great with me on it at 200lbs. Any suggestions where to start? Thanks
Old Apr 9, 2007 | 06:03 PM
LT80's Avatar
LT80 Expert
Compression test,carb cleaning, and clutch maintenence. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 9, 2007 | 08:06 PM
rgladen's Avatar
I cleaned the carb twice and just finished putting all new rollers, slides and a new spring.(before the problem arose) Tried doing some preventative maintenance before a trip.Could I have screwed something up when I did that? Wouldnt be the first time. What should the compression be? Thanks for all the suggestions.
Old Apr 9, 2007 | 09:01 PM
dealseaker's Avatar
sounds like you may have broke it, try to redo what you did and see if that fixes it
Old Apr 10, 2007 | 10:18 AM
LT80's Avatar
LT80 Expert
OK, could you have possibly got a roller(s) turned during installation?
Comp should be 120. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 14, 2007 | 04:32 PM
rgladen's Avatar
lt 80 whats the proper way to test the compression? I cranked it over till the pressure stop climbing and it was around 85 lbs. Could it be my reeds? Thanks
Old Jun 14, 2007 | 05:32 PM
LT80's Avatar
LT80 Expert
Full throttle till it peaks.
You need a new bore and piston kit. [img]i/expressions/face-icon-small-smile.gif[/img]
Reeds won't effect it that much.
Old Jun 14, 2007 | 07:10 PM
rgladen's Avatar
Any recommendation on where to purchase the parts. Thanks
Old Jun 18, 2007 | 06:10 PM
LT80's Avatar
LT80 Expert
I use Zuki pistons till the bore goes to 1.5mm over. (zuki makes up to 1.0)
Don't be talked into boring more than is needed..Most think they should bore big and get power. It just isn't so.
Old Jun 18, 2007 | 06:56 PM
rgladen's Avatar
Thanks for everything.
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
